[Proj] +towgs84 approximation error
Jochem
jochem.lesparre at kadaster.nl
Thu Mar 23 15:13:28 PDT 2017
Hi Noel,
You are right about the corrections between rotations and translations. This
will cause the parameters to look very different if you estimate them on new
data. However, besides that, I don't see what the problem is. You still get
precise transformated coordinates (and you don't always get that with
approximate formulas). Or do you see other problems?
You know the solution to this correlation problem by using a point in the
centre of the country as rotation pivot point and thus using a 10 parameter
transformation?
Section 2.4.3.2 of Guidance Note 7, part 2
<http://www.iogp.org/pubs/373-07-2.pdf> (these are approximated formulas
but of course a strict equivalent is possible).
Regards, Jochem
View this message in context: http://osgeo-org.1560.x6.nabble.com/towgs84-approximation-error-tp5313738p5313957.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
More information about the Proj
