[Proj] +towgs84 approximation error
Jochem jochem.lesparre at kadaster.nl
Fri Mar 24 02:02:35 PDT 2017
Hi Noel,
Your point on the correlations between translations and rotations was
already clear to me after your first email. However, I still don't
understand why this is so important to you. Since the coordinates
transformed with these correlated parameters won't be less accurate than the
ones with the better method you mention.
Regards, Jochem
View this message in context: http://osgeo-org.1560.x6.nabble.com/towgs84-approximation-error-tp5313738p5314008.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
