[Proj] +towgs84 approximation error
Noel Zinn (cc)
ndzinn at comcast.net
Tue Mar 28 06:40:45 PDT 2017
So many options, Jochem! Old-timer that I am, my field experience in the
late 1970s and 1980s was occupying triangulation (and traverse) points with
JMR and Magnavox TRANSIT receivers. Stochastic noise was generous with both
technologies. So, let's do something different. How about minimal
stochastics and extreme rotations? That should exacerbate the deficiencies
of either an ill-determined 7-parameter derivation or multiple regression
equations (with 7 coefficients among them, yet to be derived). Handle the
vertical as you prefer. OK? -Noel
Noel Zinn, Principal, Hydrometronics LLC
+1-832-539-1472 (office), +1-281-221-0051 (cell)
noel.zinn at hydrometronics.com (email)
http://www.hydrometronics.com (website)
-----Original Message-----
Sent: Tuesday, March 28, 2017 2:34 AM
To: proj at lists.maptools.org
Subject: Re: [Proj] +towgs84 approximation error
Hi Noel,
Thanks for your friendly response. I am back in the Netherlands now with my
normal duties. Therefore, it took a bit more time to reply.
The country I visited is definitely not a country where Gauss has been
working, considering the large rotations and scale factor.
Regarding the challenge: If you like more stochastic noise in the
observations, we can take the original coordinates of the triangulation. I
am most interested in the effect for the Netherlands (rotation angles up to
2 arc-seconds). Or would you like 40 arc-second rotations better? The
ellipsoidal heights in the old triangulation are close to the levelling
heights, or I could use our precise national geoid to compute ellipsoidal
heights.
Regards, Jochem
View this message in context:
http://osgeo-org.1560.x6.nabble.com/towgs84-approximation-error-tp5313738p5314568.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
