[Proj] Submitting proj.4 to Google OSS Fuzz ?
Even Rouault
even.rouault at spatialys.com
Tue May 23 07:09:27 PDT 2017
On mardi 23 mai 2017 13:41:50 CEST Kristian Evers wrote:
> Kurt, Even,
> Thanks for your suggestions. Very helpful. I do have access to a Linux
> server and if necessary I can work on that. It is just slightly
> inconvenient when on the move etc.
> I must say, it is a very impressive piece software google has created!
> Although it is a bit hard to grasp the finer details :-) I think I can fix
> some of the discovered issues just from looking at the report, as you
> suggest, Even.
> The only way to triggers OSS-Fuzz to test code is to commit on the
> master-branch, correct?
That's the most convenient. You can run OSS-Fuzz locally as instructed in proj.4 tests/fuzzers/
README.TXT (but you need Linux and Docker for that), and there you could point the oss-
fuzz/projects/proj4/Dockerfile to a branch of yours (that's how I tested it before submitting
it)
> /Kristian
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20170523/c7818469/attachment.html>
More information about the Proj
