[Proj] Submitting proj.4 to Google OSS Fuzz ?
Even Rouault even.rouault at spatialys.com
Tue May 23 08:23:32 PDT 2017
On mardi 23 mai 2017 14:24:11 CEST Kristian Evers wrote:
> > That's the most convenient. You can run OSS-Fuzz locally as instructed in
> > proj.4 tests/fuzzers/README.TXT (but you need Linux and Docker for that),
> > and there you could point the oss-fuzz/projects/proj4/Dockerfile to a
> > branch of yours (that's how I tested it before submitting it)
> Yeah, I figured. It would be super cool if you could trigger OSS-Fuzz
> targeting a specific bug via a pull request. Maybe that will be possible in
> the future...
> Thanks for the help. I will try to run OSS-Fuzz locally to confirm fixes
> before I commit them to master.
Well, in that case that means you're running Linux, so build proj.4 with CFLAGS="-
fsanitize=undefined,address" and running the standalone standard_fuzzer should be
sufficient (and much faster)
> Kristian
> Fra: Even Rouault [mailto:even.rouault at spatialys.com]
> Sendt: 23. maj 2017 16:09
> Til: proj at lists.maptools.org
> Cc: Kristian Evers
> Emne: Re: [Proj] Submitting proj.4 to Google OSS Fuzz ?
> On mardi 23 mai 2017 13:41:50 CEST Kristian Evers wrote:
> > Kurt, Even,
> > Thanks for your suggestions. Very helpful. I do have access to a Linux
> > server and if necessary I can work on that. It is just slightly
> > inconvenient when on the move etc.
> > I must say, it is a very impressive piece software google has created!
> > Although it is a bit hard to grasp the finer details :-) I think I can fix
> > some of the discovered issues just from looking at the report, as you
> > suggest, Even.
> > The only way to triggers OSS-Fuzz to test code is to commit on the
> > master-branch, correct?
> > /Kristian
> > Proj mailing list
> > Proj at lists.maptools.org<mailto:Proj at lists.maptools.org>
> > http://lists.maptools.org/mailman/listinfo/proj
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20170523/0b19a293/attachment.html>
