[Proj] [Live-demo] Fwd: [OSGeo-Live] Proj4 documentation
Even Rouault
even.rouault at spatialys.com
Wed May 31 13:15:27 PDT 2017
On jeudi 1 juin 2017 05:57:38 CEST Cameron Shorter wrote:
> Hi Evan,
> Yes, MetaCRS was a project gathering all the Proj4 projects together.
> However, it appears that proj4 is the only project in that grouping
> which is active?
> Hence my thoughts are that "MetaCRS" should be dropped from OSGeo-Live
> as a concept and "Proj4" be used instead. It would be ok to say "Proj4
> has been translated into other languages, including proj4js, ..."
> Your thoughts are welcome.
Regarding what is listed currently in metacrs :
- proj4js: no opinion
- cs-map: no-opinion
- geotiff/libgeotiff: heavily used underneath by GDAL in particular, mostly in maintaince
mode, but can be treated as a technical dependency that doesn't require to be visible from
users.
- proj4j: no opinion
- spatialreference.org: not maintained in years. http://epsg.io/ would be a possible
replacement
Agreed that metacrs is probably a bit too ... meta for folks exploring OSGeo-Live content, so
it could make sense exposing proj.4 as a standalone project.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20170531/dd33ef82/attachment.html>
More information about the Proj
