[Proj] Grown error if re-projecting from 4269 to LCC (2285) and backward multiple times
vanadovv at hetnet.nl
Wed Nov 1 04:29:13 PDT 2017
Hi Thomas,
LCCA: good suggestion!
As far as I can tell, there are two significant differences between LCC and LCCA.
LCC has an iteration loop criterion (in the inverse) of 1e-10, whereas LCCA is somewhat more accurate with 1e-12.
Furthermore LCCA works with a Newton iteration scheme. This could be faster than iteration by successive approximation, but there are a couple of minor inefficiencies in the code, like function calls instead of inline, but YMMV.
Oscar van Vlijmen
----Origineel Bericht----
Van : knudsen.thomas at gmail.com
Datum : 01/11/2017 07:58
Aan : vanadovv at hetnet.nl, proj at lists.maptools.org
Onderwerp : Re: [Proj] Grown error if re-projecting from 4269 to LCC (2285) and backward multiple times
Oscar,
I certainly agree that the deviation is quite high - my comment was more related
to the expection of exact roundtrips, which I find unrealistic.
Nevertheless, looking into the PROJ.4 code, I see there is an alternative
implementation of LCC, called LCCA, which I had forgotten about, which
actually seems to roundtrip exactly.
In the master branch of PROJ.4, over at
https://github.com/OSGeo/proj.4,
and comming in the next release, there is a tool "gie" for doing (a.o.)
roundtrip tests. It is still lacking in docs, but I think you can follow this example:
With this input file:
$ cat lcc-lcca.gie
BEGIN
operation +proj=lcc +lat_1=48.73333333333333 +lat_2=47.5 \
+lat_0=47 +lon_0=-120.8333333333333 \
+x_0=500000.0001016001 +y_0=0 \
+units=us-ft +ellps=GRS80 +towgs84=0,0,0 +no_defs
tolerance 0.0010 mm
accept -118.5293900000000300 48.7408309999860520
roundtrip 1000
operation +proj=lcca +lat_1=48.73333333333333 +lat_2=47.5 \
tolerance 0.0 mm
roundtrip 1000
END
I get this output:
$ gie lcc-lcca.gie
Reading file '..\..\..\proj\lcc-lcca.gie'
+proj=lcc +lat_1=48.73333333333333 +lat_2=47.5 +lat_0=47 +lon_0=-120....
FAILURE in lcc-lcca.gie(11):
roundtrip deviation: 1.550 mm, expected: 0.001 mm
total: 1 tests succeeded, 1 tests FAILED!
i.e. lcca roundtrips exactly, while lcc diverges heavily.
So Dmitry: This seems to be your workaround - define your projection using lcca,
rather than letting the epsg-list select lcc for you.
/Thomas
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20171101/1d5e8dc6/attachment.html>
More information about the Proj
