[Proj] Time for a new release?
Thomas Knudsen
knudsen.thomas at gmail.com
Fri Nov 10 07:02:19 PST 2017
Not exactly a summary, but Kristian is doing a huge effort to update docs.
He has a preview version over at https://kbevers.github.io/index.html.
You could probably profitably start at
https://kbevers.github.io/usage/transformation.html
There are some remarks about the thoughts behind the new API in the first
lines of the new header file, proj.h - find it over at
https://github.com/OSGeo/proj.4/blob/master/src/proj.h
Also, see the comments at the beginning of each function in proj_4D_api.c -
https://github.com/OSGeo/proj.4/blob/master/src/proj_4D_api.c.
We have a lot of material around, that needs to be brushed up and fit
together, but since the code has been in a state of flux, and the activity
level high, it has been next to pointless to try to document in detail.
2017-11-10 15:38 GMT+01:00 Roger Oberholtzer <roger.oberholtzer at gmail.com>:
> On Thu, Nov 9, 2017 at 11:38 AM, Kristian Evers <kreve at sdfe.dk> wrote:
> > I think the current development cycle is coming to an end and a new
> release
> > should be made.
> Is there a good summary of the changes that have been made? Especially
> of the library API?
> Roger Oberholtzer
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20171110/c8333cf3/attachment.html>
More information about the Proj
