[Proj] Time for a new release?
Charles Karney charles at karney.com
Wed Nov 15 13:15:18 PST 2017
I have a selfish wish that I should be able to build current versions of
gdal and geotiff with either proj 4.9.x or proj 5.0.x.  However it seems
that proj 5.0.x won't be backward compatible (at the source code level).
Is this right?
I don't expect proj 5.x to maintain backward compatibility indefinitely.
However, if it is possible to provide it for a year or so, that would
definitely ease the incorporation of proj 5.x into our software
ecosystem.
If this isn't possible, it would be good to get started on new versions
of gdal and geotiff which work with the new proj API.
   --Charles
On 11/15/2017 03:50 PM, Kristian Evers wrote:
> Kurt,
> I’ve hacked together a basic migration guide here
> https://kbevers.github.io/development/migration.html
> I based it on the docs for the current API. It doesn’t go into detail
> with the many undocumented functions in proj_api.h. Please let me know
> if there’s is anything you think should be added or improved in the guide.
> Kristian
>> On 11 Nov 2017, at 18:56, Kurt Schwehr <schwehr at gmail.com
>> <mailto:schwehr at gmail.com>> wrote:
>> Sorry if I am not seeing something that exists.  Is there a document
>> that explains how to transition from the old APIs to the new?
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
