[Proj] Failed to initialize PROJ.4 with "..."
stevejking
stevejking at talktalk.net
Fri Oct 13 13:41:05 PDT 2017
Kristian,
Is that a Proj4 error code?
The Proj4 codes seem more specific. My reference says code 6 is "effective
eccentricity = 1."
Is it even a GDAL error code?
Steve
Kristian Evers-2 wrote
> Chris,
> It would be beneficial if you could try to reproduce this problem just
> using PROJ.4 and a few simple coordinates. Either on the command line with
> a call to cs2cs or by a small C program. I tried initialising the
> projection with a recent version of PROJ.4 without problems and I can't
> see any obvious problem in the proj string. It is likely that if this
> indeed is a bug in PROJ.4 that it has already been fixed.
> /Kristian
> ________________________________
> Fra:
> proj-bounces at .maptools
> ] på vegne af Chris Marsh [
> chris.marsh@
> Sendt: 13. oktober 2017 17:56
> Til:
> proj at .maptools
> Emne: [Proj] Failed to initialize PROJ.4 with "..."
> Hi,
> ERROR 6: Failed to initialize PROJ.4 with `+proj=aea +lat_1=20 +lat_2=60
> +lat_0=40 +lon_0=-96 +x_0=0 +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0
> +units=m +no_defs'.
> ...Cheers
> Chris
> Proj mailing list
> Proj at .maptools
> http://lists.maptools.org/mailman/listinfo/proj
Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
More information about the Proj
