[Proj] ABI version numbers
Kristian Evers kreve at sdfe.dk
Fri Oct 27 03:05:21 PDT 2017
Not that I am aware of. There is this https://github.com/OSGeo/proj.4/issues/501 though, which gives you some idea of how the binaries how changed over time.
If you volunteer to create an overview of the ABI versions I am sure we can find somewhere in the docs to put it :-)
/Kristian
-----Oprindelig meddelelse-----
Fra: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] På vegne af Roger Oberholtzer
Sendt: 27. oktober 2017 11:45
Til: PROJ.4 and general Projections Discussions <proj at lists.maptools.org>
Emne: [Proj] ABI version numbers
Is there a document that describes which proj releases correspond to
which ABI version? For example, something that tells that 4.8.0 is ABI
9, and 4.9.3 is ABI 12. And so on?
Roger Oberholtzer
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
