[Proj] Calculating +towgs84 values from source / dest .xyz file
Mark Johnson mj10777 at googlemail.com
Mon Sep 25 05:16:52 PDT 2017
Is there a c program source that can take a list of x/y/z points for a
source and destination and calculate a valid 7 parameter +towgs84 value
that could be used with cs2cs?
I found something similar at http://helmparms3d.sourceforge.net/, called
helmparms3d - but it seems calculate values that cannot be used for
+towgs84.
Mark Johnson, Berlin Germany
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20170925/088378b7/attachment.html>
