[Proj] Calculating +towgs84 values from source / dest .xyz file
Mark Johnson
mj10777 at googlemail.com
Tue Sep 26 07:08:39 PDT 2017
José Gonçalves:: thank you for your answer, especially about which method
PROJ.4 uses (Position Vector).
Unfortunately this solution does not bring the expected result.
The original problem was the the DHDN bessel setting
(+towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7)
does not bring usable results for heights.
A manully worked
out +towgs84=598.1,73.7,418.2,0.201,0.049430,-2.455,0.2685935, gets near to
At present, the helmert3d program bring this for:
epsg:25833: 389918.0121759 5819698.8688798 34.790000000
to
epsg:3068: 23183.320000000 21047.418000000 34.790000000
reading helmert parameters...
0.999819 -0.019023 0.000000
0.019023 0.999819 -0.000000
-0.000000 0.000000 1.000000
-256025.393133 -5806493.649478 -1.442778
1.000254
+towgs84=-256025.3931332280,-5806493.6494778264,-1.4427781980,-0.0526548512,-0.0275339109,-3923.8255017867,253.6560894575
...done
dx[-256025.393133],dy[-5806493.649478],dz[-1.442778]
rx[0.052123]=-r23[0.000000252700] * 3600 * 180 / M_PI[3.141593]
ry[0.028526]= r13[0.000000138300] * 3600 * 180 / M_PI[3.141593];
rz[3923.825511]=-r12[0.019023242900] * 3600 *180 / M_PI[3.141593]
m[253.656100]=(scal[1.000254]-1) * 1000000]
starting transformation...
xout[23183.319992]=
tx(-256025.393133)+m(1.000254) *(x[389918.012176]*r11(0.999819) +
y[5819698.868880]*r12(-0.019023) + z[34.790000]*r13(0.000000))
yout[21047.418119]=
ty(-5806493.649478)+m(1.000254) *(x[389918.012176]*r21(0.019023) +
y[5819698.868880]*r22(0.999819) + z[34.790000]*r23(-0.000000))
zout[34.790125]=
tz(-1.442778)+m(1.000254) *(x[389918.012176]*r31(-0.000000) +
y[5819698.868880]*r32(0.000000) + z[34.790000]*r33(1.000000))
...done
with an exact result.
But when trying to use the +towgs84 value with cs2cs:
echo "389918.0121759 5819698.8688798 34.7900000" | cs2cs -f "%.9f"
+init=epsg:25833 +to +proj=cass +lat_0=52.41864827777778
+lon_0=13.62720366666667 +x_0=40000 +y_0=10000 +ellps=bessel
+datum=potsdam
+towgs84=+towgs84=-256025.3931332280,-5806493.6494778264,-1.4427781980,-0.0526548512,-0.0275339109,-3923.8255017867,253.6560894575
+units=m +no_defs
4383595.094518717 -889411.002599155 2829803.867439098
the result is completely off.
So something is still not correct.
Mark Johnson, Berlin Germany
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20170926/88e5c1d4/attachment.html>
More information about the Proj
