[Proj] PROJ 5.0.1
Kristian Evers kristianevers at gmail.com
Sun Apr 1 04:39:45 PDT 2018
We are pleased to announce the release of PROJ 5.0.1. This is purely a bug fixing release,
that fixes a range of problems in the initial PROJ 5 release. See the complete release
notes below.
Download it here:
	http://download.osgeo.org/proj/proj-5.0.1.tar.gz <http://download.osgeo.org/proj/proj-5.0.1.tar.gz> (http://download.osgeo.org/proj/proj-5.0.1.tar.gz.md5 <http://download.osgeo.org/proj/proj-5.0.1.tar.gz.md5>)
	http://download.osgeo.org/proj/proj-5.0.1.zip <http://download.osgeo.org/proj/proj-5.0.1.zip> (http://download.osgeo.org/proj/proj-5.0.1.zip.md5 <http://download.osgeo.org/proj/proj-5.0.1.zip.md5>)
The PROJ development team
5.0.1 Release Notes
BUG FIXES
All bug fix numbers refer to issues or pull requests indexed at
https://github.com/OSGeo/proj.4/ <https://github.com/OSGeo/proj.4/>
o Handle ellipsoid change correctly in pipelines when
  +towgs84=0,0,0 is set #881
o Handle the case where nad_ctable2_init returns NULL #883
o Avoid shadowed declaration errors with old gcc #880
o Expand +datum properly +datum in pipelines #872
o Fail gracefully when incorrect headers are encountered in grid
  files #875
o Improve roundtrip stability in pipelines using +towgs84 #871
o Fixed typo in gie error codes #861
o Numerical stability fixes to the geodesic package #826 #843
o Make sure that transient errors are returned correctly #857
o Make sure that locally installed header files are not used when
  building PROJ #849
o Fix inconsistent parameter names in proj.h/proj_4D_api.c #842
o Make sure +vunits is applied #833
o Fix incorrect Web Mercator transformations #834
THANKS TO
Version 5.0.1 is made possible by the following contributors:
  Mike Toews
  Kurt Schwehr
  Even Rouault
  Charles Karney
  Thomas Knudsen
  Kristian Evers
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180401/5028ae89/attachment.html>
