[Proj] [gdal-dev] gdalinfo error and subsequent segfault with proj-5.0.x
Even Rouault
even.rouault at spatialys.com
Sun Apr 15 13:07:43 PDT 2018
> OK, I recompiled gdal-2.2.4 --with-static-proj4 and got
> ldd libgdal.so | grep proj
> libproj.so.13 => /usr/local/lib64/libproj.so.13 (0x00007fe2ff181000)
> libproj.so.12 => /lib64/libproj.so.12 (0x00007fe2f31c7000)
> gdalinfo now runs fine and produces expected results.
> I'm still concerned about the output of ldd libgdal.so
Yes that's not sane. That means that GDAL links to a library that links to the
system libproj (/lib64/libproj.so.12), whereas GDAL directly links to your
custom libproj 5 build ( /usr/local/lib64/libproj.so.13) . That may crash as
well.
As proj 5.0.1 is (I believe) ABI compatible with previous releases, one
potential hack is to make
sudo ln -s /usr/local/lib64/libproj.so.13 /usr/local/lib64/libproj.so.12
and define LD_LIBRARY_PATH to point to /usr/local/lib64/
A cleaner solution would be to identify the GDAL dependenci(es) that link to
/lib64/libproj.so.12 and rebuild them against the one in /usr/local/lib64/
libproj.so.13
http://www.spatialys.com
More information about the Proj
