[Proj] Code style in Proj
Thomas Knudsen
knudsen.thomas at gmail.com
Tue Apr 24 02:45:33 PDT 2018
> In C too, but since C99.
AFAIK this only applies to the "for (int i = 0; i < n; i++)" syntax.
while (...) {
int i = 123, j = 345;
k = i + j;
has been correct (and imho, preferable) syntax since K&R C
/Thomas
2018-04-23 0:17 GMT+02:00 Mateusz Loskot <mateusz at loskot.net>:
> On 22 April 2018 at 20:07, Kurt Schwehr <schwehr at gmail.com> wrote:
> > Kristian,
> > Things to do when you are about to have a kid and want a distraction :)
> Congratulations! I still remember that distraction pursuit myself ;-)
> > On Sun, Apr 22, 2018 at 8:10 AM, Kristian Evers <kreve at sdfe.dk> wrote:
> >> - Combine definition and declaration
> >> It works in this example but I don’t think it can be enforced in more
> >> complicated code.
> >> Variable declarations have to be made at the start of a block and that
> is
> >> not always possible.
> > Agreed. Not always possible or always a good thing. And a style
> question
> > is do you allow variables to be defined in sub scopes? In C++, the
> answer
> > is usually to keep things as tight/narrow as possible.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180424/f3d1de75/attachment.html>
More information about the Proj
