[Proj] building, testing from git repository -- 'ctest' failures
Greg Minshall minshall at acm.org
Fri Aug 31 07:44:16 PDT 2018
Kristian,
thanks.  combining the contents of proj-datum and proj.4/nad in my
$PROJ_LIB fixed all but one of the failures.
The following tests FAILED:
         12 - DHDN_ETRS89 (Failed)
Errors while running CTest
i'm not sure what this is, but i'm satisfied i'm basically running.
whereas "make check" apparently runs without errors.  (i'll look into
this last error when i'm able.)
thanks for the pointer -- now i've looked at install.sh.  i'll try to
rely on it for the future.
cheers, Greg
