[PROJ] What's the difference between PJ and PJ_OBJ?
Kurt Schwehr schwehr at gmail.com
Tue Dec 18 12:12:27 PST 2018
I was going to suggest getting everything to build as C++ in the lib.
Thanks Kristian for beating me to the suggestion and to Even for all the
hard work!!!
On Tue, Dec 18, 2018 at 10:57 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> > Since we require compilation with a C++ compiler now it is too
> far-fetched
> > an idea to compile everything as C++. It would be interesting to see if
> > this is possible without too much extra work.
> I'm taking a crack at that right now. Seems doable.
> What C++ doesn't like at all is the implict cast from void* to
> something_else*, that need to be explicited in C++ as static_cast<>()
> Beyond those errors, a lot warnings which seem to be exclusively instances
> of
> -Wzero-as-null-pointer-constant. clang-tidy should be able to convert
> those.
> > I guess that modification of proj_create-functions wouldn't take too much
> > work
>  since most is already done in the C++ parts of the code. We still
> > have to keep pj_init() and friends alive for a little while longer. Will
> > that pose a problem or can all the work be delegate to
> > PROJStringParser::createFromPROJString() ?
> > In case of the technical objects, could that be handled by using the
> > recently proposed "noop" operation?
> I think that an "invalid" operation would be a better fit for those. We
> don't
> want such objects to be confused with valid coordinate transformation
> "noop" is a valid operation when there is nothing to do except passthrough
> coordinates. If the PJ object you got is let's say a prime meridian, it is
> better if proj_trans() returns an error rather than the input values.
> (but that's just a detail)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20181218/423125cb/attachment.html>
More information about the PROJ mailing list
