[Proj] PROJ 5.0.0RC1 Released
Julien Moquet
moquet.julien at gmail.com
Mon Feb 5 14:08:34 PST 2018
Hi Kristian,
I've got an improvement :
THANKS TO
Version 5.0.0 is made possible by the following contributors:
Lukasz Komsta
Maxim Churilin
edechaux
dusanjovic
Zoltan Siki
Tom Fili
Nicolas David
Mike Toews
Micah Cochran
Luke Campbell
Ilya Oshchepkov
Adam Wulkiewicz
Jonas Tittmann
Mateusz Loskot
Etienne Jacques
Bas Couwenberg
Elliott Sales de Andrade
Charles Karney
Aaron Puchert
Julien Moquet
Charles Karney
Howard Butler
Even Rouault
Thomas Knudsen
Kristian Evers
You forgot yourself.
Well done !
Regards,
2018-02-02 16:02 GMT+01:00 Kristian Evers <kreve at sdfe.dk>:
> All,
> I have prepared the first release candidate of PROJ 5.0.0. See the release
> notes below. Since this release brings many substantial changes I expect
> that we will be going through a number of RCs before the final release is
> ready. We are aiming for a March 1st final release.
> Please test the release candidate where ever you depend on it and report
> back your findings.
> Download it here:
> http://download.osgeo.org/proj/proj-5.0.0RC1.tar.gz (
> http://download.osgeo.org/proj/proj-5.0.0RC1.tar.gz.md5)
> http://download.osgeo.org/proj/proj-5.0.0RC1.zip (
> http://download.osgeo.org/proj/proj-5.0.0RC1.zip.md5)
> /Kristian
> 5.0.0 Release Notes
> This version of PROJ introduces some significant extensions and
> improvements to (primarily) the geodetic functionality of the system.
> The main driver for introducing the new features is the emergence of
> dynamic reference frames, the increasing use of high accuracy GNNS,
> and the related growing demand for accurate coordinate
> transformations. While older versions of PROJ included some geodetic
> functionality, the new framework lays the foundation for turning PROJ
> into a generic geospatial coordinate transformation engine.
> The core of the library is still the well established projection code.
> The new functionality is primarily exposed in a new programming
> interface and a new command line utility, "cct" (for "Coordinate
> Conversion and Transformation"). The old programming interface is
> still available and can - to some extent - use the new geodetic
> transformation features.
> The internal architecture has also seen many changes and much
> improvement. So far, these improvements respect the existing
> programming interface. But the process has revealed a need to simplify
> and reduce the code base, in order to support sustained active
> development.
> !!! Therefore we have scheduled regular releases over the coming years
> !!! which will gradually remove the old programming interface.
> !!! This will cause breaking changes with the next two major version
> !!! releases, which will affect all projects that depend on PROJ
> !!! (cf. section "deprecations" below).
> The decision to break the existing API has not been easy, but has
> ultimately been deemed necessary to ensure the long term survival of
> the project. Not only by improving the maintainability immensely, but
> also by extending the potential user (and hence developer) community.
> The end goal is to deliver a generic coordinate transformation
> software package with a clean and concise code base appealing to
> both users and developers.
> VERSIONING AND NAMING
> For the first time in more than 25 years the major version number of
> the software is changed. The decision to do this is based on the many
> new features and new API. While backwards compatibility remains -
> except in a few rare corner cases - the addition of a new and improved
> programming interface warrants a new major release.
> The new major version number unfortunately leaves the project in a bit
> of a conundrum regarding the name. For the majority of the life-time
> of the product it has been known as PROJ.4, but since we have now
> reached version 5 the name is no longer aligned with the version
> number.
> Hence we have decided to decouple the name from the version number and
> from this version and onwards the product will simply be called PROJ.
> In recognition of the history of the software we are keeping PROJ.4 as
> the *name of the organizing project*. The same project team also
> produces the datum-grid package.
> In summary:
> o The PROJ.4 project provides the product PROJ, which is now at
> version 5.0.0.
> o The foundational component of PROJ is the library libproj.
> o Other PROJ components include the application proj, which provides
> a command line interface to libproj.
> o The PROJ.4 project also distributes the datum-grid package,
> which at the time of writing is at version 1.6.0.
> UPDATES
> o Introduced new API in proj.h.
> - The new API is orthogonal to the existing proj_api.h API and the
> internally used projects.h API.
> - The new API adds the ability to transform spatiotemporal (4D)
> coordinates.
> - Functions in the new API use the "proj_" namespace.
> - Data types in the new API use the "PJ_" namespace, with a few
> historic exceptions such as XY, XYZ, LP and LPZ.
> o Introduced the concept of "transformation pipelines" that makes it
> possible to do complex geodetic transformations of spatiotemporal
> coordinates by daisy chaining simple coordinate operations.
> o Introduced cct, the Coordinate Conversion and Transformation
> application.
> o Introduced gie, the Geospatial Integrity Investigation Environment.
> - Selftest invoked by -C flag in proj has been removed
> - Ported approx. 1300 built-in selftests to gie format
> - Ported approx. 1000 tests from the gigs test framework
> - Added approx. 200 new tests
> o Adopted terminology from the OGC/ISO-19100 geospatial standards
> series. Key definitions are:
> - At the most generic level, a *coordinate operation* is a change
> of coordinates, based on a one-to-one relationship, from one
> coordinate reference system to another.
> - A *transformation* is a coordinate operation in which the two
> coordinate reference systems are based on different datums, e.g.
> a change from a global reference frame to a regional frame.
> - A *conversion* is a coordinate operation in which both
> coordinate reference systems are based on the same datum,
> e.g. change of units of coordinates.
> - A *projection* is a coordinate conversion from an ellipsoidal
> coordinate system to a plane. Although projections are simply
> conversions according to the standard, they are treated as
> separate entities in PROJ as they make up the vast majority
> of operations in the library.
> o New operations:
> - The pipeline operator (pipeline)
> - Transformations:
> + Helmert transform (helmert)
> + Horner real and complex polynomial evaluation (horner)
> + Horizontal gridshift (hgridshift)
> + Vertical gridshift (vgridshift)
> + Molodensky transform (molodensky)
> + Kinematic gridshift with deformation model (deformation)
> - Conversions:
> + Unit conversion (unitconvert)
> + Axis swap (axisswap)
> - Projections:
> + Central Conic projection (ccon)
> o Significant documentation updates, including
> - Overhaul of the structure of the documentation
> - A better introduction to the use of PROJ
> - A complete reference to the new proj.h API
> - a complete rewrite of the section on geodesic calculations
> - Figures for all projections
> o New "free format" option for operation definitions, which
> permits separating tokens by whitespace when specifying key/value-
> pairs, e.g. "proj = merc lat_0 = 45".
> o Added metadata to init-files that can be read with the
> proj_init_info() function in the new proj.h API.
> o Added ITRF2000, ITRF2008 and ITRF2014 init-files with ITRF
> transformation parameters, including plate motion model
> parameters.
> o Added ellipsoid parameters for GSK2011, PZ90 and "danish". The
> latter is similar to the already supported andrae ellipsoid,
> but has a slightly different semimajor axis.
> o Added Copenhagen prime meridian.
> o Updated EPSG database to version 9.2.0.
> o Geodesic library updated to version 1.49.1-c.
> o Support for analytical partial derivatives has been removed.
> o Improved performance in Winkel Tripel and Aitoff.
> o Introduced pj_has_inverse() function to proj_api.h. Checks if an
> operation has an inverse. Use this instead of checking whether
> P->inv exists, since that can no longer be relied on.
> o Removed support for Windows CE.
> o Removed the VB6 COM interface.
> BUG FIXES
> All bug fix numbers refer to issues indexed at
> https://github.com/OSGeo/proj.4/issues/
> o Fixed incorrect convergence calculation in Lambert Conformal
> Conic. #16.
> o Handle ellipsoid parameters correctly when using +nadgrids=@null.
> #22.
> o Return correct latitude when using negative northings in
> Transverse Mercator (tmerc). #138.
> o Return correct result at origin in inverse Mod. Stererographic
> of Alaska. #161.
> of 48 U.S. #162.
> of 50 U.S. #163.
> o Return correct result at origin in inverse Lee Oblated
> Stereographic. #164.
> o Return correct result at origin in inverse Miller Oblated
> o Fixed scaling and wrap-around issues in Oblique Cylindrical
> Equal Area. #166.
> o Corrected a coefficient error in inverse Transverse Mercator. #174.
> o Respect -r flag when calling proj with -V. #184.
> o Remove multiplication by 2 at the equator error in Stereographic
> projection. #194.
> o Allow +alpha=0 and +gamma=0 when using Oblique Mercator. #195.
> o Return correct result of inverse Oblique Mercator when alpha is
> between 90 and 270. #331.
> o Avoid segmentation fault when accessing point outside grid. #369.
> o Avoid segmentation fault on NaN input in Robin inverse. #463.
> o Very verbose use of proj (-V) on Windows is fixed. #484.
> o Fixed memory leak in General Oblique Transformation. #497.
> o Equations for meridian convergence and partial derivatives have
> been corrected for non-conformal projections. #526.
> o Fixed scaling of cartesian coordiantes in pj_transform(). #726.
> o Additional bug fixes courtesy of Googles OSS-Fuzz program:
> https://bugs.chromium.org/p/oss-fuzz/issues/list?can=1&q=proj4
> DEPRECATIONS
> o The projects.h header and the functions related to it is
> considered deprecated from version 5.0.0 and onwards.
> !!! PROJECTS.H WILL BE REMOVED FROM THE LIBRARY !!!
> !!! WITH VERSION 6.0.0 !!!
> o The nmake build system on Windows will not be supported from
> version 6.0.0 on onwards. Use CMake instead.
> !!! NMAKE BUILD SYSTEM WILL BE REMOVED FROM THE LIBRARY !!!
> o The proj_api.h header and the functions related to it is
> consided deprecated from version 5.0.0 and onwards.
> !!! PROJ_API.H WILL BE REMOVED FROM THE LIBRARY !!!
> !!! WITH VERSION 7.0.0 !!!
> THANKS TO
> Lukasz Komsta
> Maxim Churilin
> edechaux
> dusanjovic
> Zoltan Siki
> Tom Fili
> Nicolas David
> Mike Toews
> Micah Cochran
> Luke Campbell
> Ilya Oshchepkov
> Adam Wulkiewicz
> Jonas Tittmann
> Mateusz Loskot
> Etienne Jacques
> Bas Couwenberg
> Charles Karney
> Aaron Puchert
> Julien Moquet
> Charles Karney
> Howard Butler
> Even Rouault
> Thomas Knudsen
> Kristian Evers
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180205/607dd790/attachment.html>
More information about the Proj
