[Proj] Cct, proj_create_crs_to_crs and towgs84 parameters
Thomas Knudsen
knudsen.thomas at gmail.com
Mon Feb 12 01:53:26 PST 2018
Hello Olli,
Thanks for testing and reporting! Your report probably relates to a bug
which has been fixed
in pull request #793 over at https://github.com/OSGeo/proj.4/pull/793
Unfortunately, the build fails, due to something which *may* be a bug in
cppcheck (the code
compiles cleanly on all platforms, but cppcheck reports a syntax error).
I'll have to look into
this before merging the PR.
Running locally, my current build reports the following on your test
material:
$ echo 3500000 6650000 0 | bin\Debug\cs2cs_d +init=epsg:2393 +to
+init=epsg:3879
25611546.42 6651551.63 25.30
$ echo 3500000 6650000 0 | bin\Debug\cct_d -t0 +proj=pipeline +step
+init=epsg:2393 +inv +step +init=epsg:3879
25611546.4190 6651551.6301 25.2952 0.0000
/Thomas
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180212/c0a4c967/attachment.html>
More information about the Proj
