[Proj] PROJ 5.0.0RC4
Kristian Evers kreve at sdfe.dk
Wed Feb 21 09:58:13 PST 2018
Sorry, I failed to mentioned that. It is my plan to also make a new release of the datumgrid package at the same time as PROJ 5.0.0.
Now that both the BETA2007 grid, the Australian and Danish grids have been added we should definitely put out a new version.
I had not thought of doing a release candidate though. If you feel that is important, Bas, I will publish one. Otherwise I’ll just make
sure that the two packages get updated at the same time.
/Kristian
> On 21 Feb 2018, at 18:19, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
> On 02/21/2018 05:27 PM, Kristian Evers wrote:
>> Changes from RC3 are minor. The PostGIS guys found a bug related to error-reporting otherwise no functional changes.
>> RC3 has also seen more testing on Windows via the prerelease package added to OSGeo4W. I expect this to be the final
>> release candidate. I will call for a vote for promotion to final release on the 27th. Unless serious issues are discovered in the
>> mean time.
> The nad/BETA2007.gsb file is still not included in proj-5.0.0RC4. Since
> it is included in proj-datumgrid, a new release (1.7RC1?) of
> proj-datumgrid should be published so that the new grids can be included
> alongside in proj packages alongside the 5.0.0 code changes.
> Kind Regards,
> Bas
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
