[Proj] Pipeline +init files, inverse
Kristian Evers kreve at sdfe.dk
Thu Feb 22 00:20:47 PST 2018
+inv is only valid within a pipeline. That's why my last example was
	<7709-3D_reverse>  +proj=pipeline +step +init=transforms:7709-3D +inv
even though it is a pipeline with a single step, it is necessary because otherwise the +inv
would not have an effect. This stuff is also in the documentation for the next release:
https://kbevers.github.io/usage/operations/pipeline.html (preliminary address until PROJ 5 is released).
/Kristian
-----Oprindelig meddelelse-----
Fra: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] På vegne af stevejking
Sendt: 22. februar 2018 09:05
Til: proj at lists.maptools.org
Emne: Re: [Proj] Pipeline +init files, inverse
Thanks Kristian and Thomas
I’ll give these a try on RC4
cct +init = blabla +inv
Doesn’t work on RC3 if it’s supposed to.
But I’m sure
cct -i +init = blabla
and the others will work
Steve
Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
