[Proj] Pipeline +init files, inverse
stevejking stevejking at talktalk.net
Thu Feb 22 23:46:58 PST 2018
Kristian,
Thanks for the reply, I'll take a look at the link.
For the moment, I've added the missing +step to case 3, and it now works :)
I also removed the command line -t0's which I had in error put in the init
file.
Unfortunately case 2 is still giving the error. I even tried removing the
breakline \'s.
Will look more when time allows.
Steve
Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
