[Proj] PROJ 5.0.0RC5
Marco Atzeri
marco.atzeri at gmail.com
Sat Feb 24 08:59:54 PST 2018
On 23/02/2018 20:19, Kristian Evers wrote:
> All,
> I have prepared PROJ 5.0.0RC5. Downloads are here:
> http://download.osgeo.org/proj/proj-5.0.0RC5.tar.gz (http://download.osgeo.org/proj/proj-5.0.0RC5.tar.gz.md5)
> http://download.osgeo.org/proj/proj-5.0.0RC5.zip (http://download.osgeo.org/proj/proj-5.0.0RC5.zip.md5)
> Since RC4 problems with vertical grid installation, the Horner
> transformation and faulty polygon area calculation
> in geodesic library has been fixed. Hopefully this will be the final
> release candidate. I will call for a vote for
> promotion to final release on the 27th. Unless serious issues are
> discovered in the mean time.
> /Kristian
on cygwin 64 bit it passes most of the tests, except
Reading file
'/cygdrive/e/cyg_pub/devel/proj/prova/proj-5.0.0-0.5a.x86_64/src/proj-5.0.0/test/gie/4D-API_cs2cs-style.gie'
proj=latlong nadgrids=nzgd2kgrid0005.gsb ellps=GRS80
Invalid operation definition in line no. 55:
(null) (errno=PJD_ERR_UNKNOWN/0)
proj=latlong geoidgrids=egm96_15.gtx ellps=GRS80
Invalid operation definition in line no. 71:
proj=merc geoidgrids=egm96_15.gtx ellps=GRS80
Invalid operation definition in line no. 84:
proj=latlong geoidgrids=egm96_15.gtx axis=neu ellps=GRS80
Invalid operation definition in line no. 104:
Invalid operation definition in line no. 124:
total: 4 tests succeeded, 7 tests skipped, 5 tests FAILED!
PROJ_LIB=/cygdrive/e/cyg_pub/devel/proj/prova/proj-5.0.0-0.5a.x86_64/src/proj-5.0.0/nad
../../src/gie
/cygdrive/e/cyg_pub/devel/proj/prova/proj-5.0.0-0.5a.x86_64/src/proj-5.0.0/test/gie/unitconvert.gie
Reading file
'/cygdrive/e/cyg_pub/devel/proj/prova/proj-5.0.0-0.5a.x86_64/src/proj-5.0.0/test/gie/deformation.gie'
total: 5 tests succeeded, 2 tests skipped, 2 tests FAILED!
Reading file
'/cygdrive/e/cyg_pub/devel/proj/prova/proj-5.0.0-0.5a.x86_64/src/proj-5.0.0/test/gie/more_builtins.gie'
proj=hgridshift grids=nzgd2kgrid0005.gsb ellps=GRS80
Invalid operation definition in line no. 214:
pj_cart_selftest fails with 64
total: 44 tests succeeded, 2 tests skipped, 3 tests FAILED!
More information about the Proj
