[Proj] PROJ 5.0.0RC5
    Jeff McKenna
    jmckenna at gatewaygeomatics.com
    Wed Feb 28 15:38:18 PST 2018
Update: I never heard back from anyone else about testing PROJ v5 +
MapServer (and GDAL), so in fact I may be the only person to test this
combination so far.  Because this is a PROJ mailing list I first give
some more feedback with PROJ utilities, then later will list results
from other software for anyone interested.  (in reality I first noticed
the problem in MapServer but then each test in GDAL then PROJ failed as
well, on Windows with PROJ 5.0.0-RC6)
cs2cs
I wanted to test PROJ v5 by using a point
(487147.594520173,4934316.46263998) in EPSG:26915 (UTM Zone 15) and
reprojecting that to EPSG:3857 (Google's Mercator).
with PROJ 4.9.3
cs2cs -v +proj=utm +zone=15 +datum=NAD83 +to +proj=merc +a=6378137
+b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m
+nadgrids=@null
# ---- From Coordinate System ----
#Universal Transverse Mercator (UTM)
#       Cyl, Sph
#       zone= south
# +proj=utm +zone=15 +datum=NAD83 +ellps=GRS80 +towgs84=0,0,0
# ---- To Coordinate System ----
#Mercator
#       Cyl, Sph&Ell
#       lat_ts=
# +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
+y_0=0 +k=1.0
# +units=m +nadgrids=@null
487147.594520173 4934316.46263998
RESULT POINT: -10370728.80    5552839.74 -0.00
with PROJ 5.0.0-RC6
+nadgrids=@null
#       Cyl, Sph
#       zone= south
#Mercator
#       Cyl, Sph&Ell
#       lat_ts=
+y_0=0 +k=1.0
RESULT POINT: -10370728.80    5522830.15 -10484.03
Discussion
PROJ 4.9.3 returns the correct value (I've confirmed this with many
other tools including QGIS).  Can someone explain why those 2 results
are different? (I have reproduced this problem on Windows and also
Ubuntu 14.94)
GDAL
I wanted to test PROJ v5 by using that same test point (as a shapefile)
in EPSG:26915 (UTM Zone 15) and reprojecting that to EPSG:3857 (Google's
Mercator), using GDAL's ogr2ogr command.  (data used:
https://www.gatewaygeomatics.com/dl/parcels-proj-v5-test.zip )  Below I
have used the ogr2ogr command (included in the "commands.txt" file in
that data download) and then ogrinfo on the reprojected file to output:
with PROJ 4.9.3
POINT (-10370728.7959208 5552839.74177463)
with PROJ 5.0.0-RC6
POINT (-10370728.7959208 5522830.1464459)
Discussion
PROJ 4.9.3 compiled into GDAL 2.2.3 returns the correct point value, but
returns a different point value with PROJ 5.0.0-RC6
Same problems as GDAL (reprojected layer has different extents with PROJ
5.0.0-RC6, causing problems to display the reprojected layer in a map
image).
If you made it this far in my long email, thanks for listening (I am
totally stumped on this one, again ha).
-jeff
On 2018-02-25 3:45 PM, Kristian Evers wrote:
> Thanks for testing, Jeff. It is very appreciated. I hope you sort of your problems,
> PROJ-related or not.
> /Kristian
>> On 25 Feb 2018, at 00:29, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>> Update: it seems many things were happening, causing me to look in wrong
>> places.  But in the end MapServer was in fact reprojecting the points;
>> what caused me total confusion was that I was testing with several
>> MapServer-related applications that are part of MS4W (Mapbender,
>> GeoMOOSE) and one application had a totally blank opening map image with
>> PROJ v5.  In fact for some reason the old hardcoded map extents
>> (displayed in EPSG:3857) no longer display the data (you have to now
>> zoom out a bit to see the data, reprojected with PROJ v5).  I'll contact
>> the GeoMOOSE team to let them dive into this (still, it could be my
>> Windows environment, as no one else seems to be testing MapServer + PROJ
>> v5 yet).
>> Very sorry for all this noise!
>> Short story: all is fine with RC5 here.
>> Thank you again Kristian for your passion driving this.
>> -jeff
>> On 2018-02-23 5:33 PM, Jeff McKenna wrote:
>>> Hi Kristian,
>>> No problems here on Windows in the MS4W environment, but I'm running
>>> into odd errors when I have MapServer call PROJ 5
>>> (https://lists.osgeo.org/pipermail/mapserver-dev/2018-February/015347.html).
>>>    Obviously an issue downstream not here, but I thought I'd at least
>>> mention it here that I am testing RC5 as well :)
>>> Thanks for pushing this release along.
>>> -jeff
>>> On 2018-02-23 3:19 PM, Kristian Evers wrote:
>>>> All,
>>>> I have prepared PROJ 5.0.0RC5. Downloads are here:
>>>> http://download.osgeo.org/proj/proj-5.0.0RC5.tar.gz (http://download.osgeo.org/proj/proj-5.0.0RC5.tar.gz.md5)
>>>> http://download.osgeo.org/proj/proj-5.0.0RC5.zip (http://download.osgeo.org/proj/proj-5.0.0RC5.zip.md5)
>>>> Since RC4 problems with vertical grid installation, the Horner
>>>> transformation and faulty polygon area calculation
>>>> in geodesic library has been fixed. Hopefully this will be the final
>>>> release candidate. I will call for a vote for
>>>> promotion to final release on the 27th. Unless serious issues are
>>>> discovered in the mean time.
>>>> /Kristian
More information about the Proj
