[Proj] [proj] Migration from travis-ci.org to travis-ci.com
Kristian Evers kreve at sdfe.dk
Fri Jun 1 11:51:44 PDT 2018
Awesome. That should speed things up a bunch! Thanks for taking care of this.
Maybe related to this change, I have noticed that the website is not being deployed properly at the moment. That is, it isn’t being deployed at all. Previously this has been caused by failure to generate the PDF docs but I can’t find any hints in the logs that that is the problem. I am wondering if maybe the switch to the .com domain has had an effect on the deploy key or something like that?
/Kristian
> On 1 Jun 2018, at 17:21, Even Rouault <even.rouault at spatialys.com> wrote:
> Hi,
> Thanks to OSGeo financial support, repositories under the OSGeo github
> organizations have now a maximum 13 concurrent jobs available on travis-ci.com
> Note that the builds are now on the .com domain, and no longer on the .org.
> This is related to their on-going migration from the .org to the .com. The
> logs of the builds on .org are still available, but no new builds won't be
> triggered on the .org now.
> So head to:
> 	https://travis-ci.com/OSGeo/gdal/
> 	https://travis-ci.com/OSGeo/proj.4/
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
