[Proj] PROJ 5.0.0RC6
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Mar 1 11:21:38 PST 2018
Thanks Kristian.  Regarding the announcement, if you email the text you
need published to news_item(at)osgeo.org it will be magically sent
through Twitter, new website, Discuss list etc.
-jeff
On 2018-03-01 3:10 PM, Kristian Evers wrote:
> Jeff,
> That would also be the ideal case, I agree. The release process was started two days ago with the vote on the MetaCRS list.
> Also, and this is actually the most pressing issue, my available time is limited the following weeks so I wouldn’t be able to
> properly follow up on yet another RC.
> Aside from the issue you have reported the release seem to be in good shape. There is a work around to the know issue
> with the web mercator (remove +nadgrids=@null from the proj-string) so early adopters should be able to get going anyway.
> I am sure more issues will rise to the surface once the final release is out in the wild. Those along with the web mercator
> thing will be fixed in a short while in 5.0.1.
> Don’t feel bad about improving the software! It is very appreciated and I can only hope that more will do the same in the future!
> /Kristian
>> On 1 Mar 2018, at 20:03, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>> Anyway sorry that I caused all this grief with my testing.  Congrats on
>> this massive release!!
>> -jeff
>> On 2018-03-01 2:52 PM, Jeff McKenna wrote:
>>> Actually I assumed that this would call for an immediate RC7 release.
>>> (as it affects so many projects downstream, for [unfortunately] the most
>>> translated projection today).  -my thoughts, jeff
>>> On 2018-03-01 2:18 PM, Kristian Evers wrote:
>>>> I’ve been thinking about this all day. Initially I was planing to add the fix to the map server problem, but it is not
>>>> particularly smart to add stuff without an RC I guess. The current release candidate seems to behave quite well,
>>>> apart from that one thing which has a known work-around. I’ll plan for a patch release around April 1st. If the
>>>> number of reported bugs is low I’ll consider not issuing 5.0.1.
>>>> I’ll get to work on packing 5.0.0.
>>>> /Kristian
>>>>> On 1 Mar 2018, at 19:07, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
>>>>> On 03/01/2018 06:39 PM, Kristian Evers wrote:
>>>>>> Well, I was sort of going to play It by ear with regards to patch releases. 5.1.0 will be around June 1st.
>>>>>> But maybe it isn’t such a bad idea to already schedule the first pure bug-fixing release in a month time or so.
>>>>>> Jeff’s (well.. my bug, discovered by Jeff) could then be applied in that release instead of sneaking
>>>>>> It in the final release. The vote promoting RC6 to final has more or less passed on the MetaCRS list
>>>>>> less than an hour ago.
>>>>>> See the release schedule here: https://github.com/OSGeo/proj.4/milestones?direction=asc&sort=due_date&state=open
>>>>>> What are your thoughts on that?
>>>>> The next release in June is quite reasonable, although not strictly a
>>>>> bugfix release.
>>>>> If there aren't many regressions reported before that time, leaving the
>>>>> planned release dates as-is is probably fine.
>>>>> Otherwise scheduling a bugfix release before that time, 4-6 weeks after
>>>>> the 5.0.0 release, is probably a good idea.
>>>>> Kind Regards,
>>>>> Bas
