[Proj] How can I get transformation matrix from `invproj`?
    Ken Mankoff
    mankoff at gmail.com
    Tue Mar 13 06:00:18 PDT 2018
I'm working with data on a rotated pole. I can project from "real world" to
"rotated" coordinates with the following command:
invproj -f "%f" +proj=ob_tran +o_proj=latlon +o_lon_p=-200 +o_lat_p=18
+lon_0=180 -m 57.295779506
I'd like to adjust some GRASS vectors. They aren't simple point vectors so
I can't easily export | invproj | import. However, GRASS does have a
v.transform command https://grass.osgeo.org/grass74/manuals/v.transform.html
I'm having trouble figuring out two things:
1) What is the translation and rotation that occurs based on the invproj
command above
2) How to I convert that information to the x y shift and z rotate expected
by the v.transform command.
I'm hoping this list can help with the first?
Thank you,
  Ken Mankoff
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180313/8cdb35e1/attachment.html>
More information about the Proj
