[Proj] Use of SQLite
Even Rouault even.rouault at spatialys.com
Mon May 21 07:37:17 PDT 2018
Greg,
>   proj needs to be portable, and that precludes shipping a sqlite3
>   binary file.  Presumably the source code will contain either some text
>   file that is loaded as part of the build process, and binary packages
>   will have binary sqlite3 files?  Or something else?
>   (Assuming source file at build time) It's unclear if you mean the
>   source file to be a sqlite3 db dump, and if that will be in the VCS,
>   or something else?   There seems to be merit in having a simple csv
>   format in the source tree.   But perhaps sqlite3 dump is the new
>   lingua franca.
The idea would be to have in git one or several .sql files that are parts of the SQLite dump.
The advantage with this text-based view is that we can easily follow changes of content
(contrary for example to QGIS srs.db which is in binary format only in git, which makes it hard
to know which exact changes are done)
'make' would then use the sqlite3 binary installed on the build machine to build the final
proj_srs.db from the source .sql files, and make install would install it in proj resource files
(the source .sql files wouldn't be installed)
libsqlite3 should be available at runtime on the target architecture of the build.
>   (not entirely related) My impression is that the EPSG database is
>   non-Free, and I wonder if the "modified version" becomes free, or if
>   this is still an issue to resolve.
That's already an issue we've encountered with: libgeotiff, GDAL, proj, QGIS, PostGIS SRS
databases are all derived, to different extent, from the EPSG database.
>From https://lists.osgeo.org/pipermail/metacrs/2015-August/000855.html
The EPSG ToS limitions don't seem to apply to derived subsets as long as
they aren't attributed to the EPSG Dataset.
In Debian we consider the derived EPSG data in proj/nad/epsg for example
to fall under the MIT license of PROJ.4, because these are subsets of
the EPSG data."""
Other actors of the GIS industry have also evaluated that they could publish data partly
derived from the EPSG database under Apache V2:
https://github.com/Esri/projection-engine-db-doc
This discussion about licensing of data coming from the EPSG database is orthogonal to
which storage is used.
>   Have you thought about the minimum version?  I am unclear how many
>   systems include sqlite in the base system, and at which versions.  So
>   if proj were able to work with fairly old sqlite (even if you would
>   recommend that people have newer), that would be good.   Basically,
>   from a packaging viewpoint, while newer is usually better, it's
>   preferred to have as few forcing functions in the dependency graph as
>   possible.
I mentionned sqlite 3.7 to be able to use the _v2 API of it. Actually I see that CentOS 6, which
is probably one of the most ancient maintained Linux distribution, ships with sqlite 3.6.20
and it already has sqlite3_open_v2() and sqlite3_prepare_v2(), so that could be a minimum
target.
>   I don't entirely follow the notion of using some other db.  The nice
>   thing about sqlite is that it's linked in and you don't need to
>   configure a db username and have a process running.  Once you do that,
>   things are much harder and more fragile, and there are security issues
>   if the db doesn't default to listening only on localhost.   But I can
>   see the idea that some might want this.   One Option might be for postgis
>   to read the proj db at build time, and essentially shadow it, which
>   would involve  a way to read out the db -- which would be nice to not
>   be in sqlite dump language.
I just mentionned this to be transparent and reflect discussions. I imagine that this
hypothetical abstraction layer could just reuse an existing PostgreSQL connection. But as I
said, I'd prefer we avoid this.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180521/0e582948/attachment.html>
