[Proj] Use of SQLite
Even Rouault
even.rouault at spatialys.com
Mon May 21 11:54:00 PDT 2018
On lundi 21 mai 2018 11:35:07 CEST Kurt Schwehr wrote:
> Sorry I haven't chimed in sooner. Going with SQLite is certainly fine for
> my particular env. Here is what I would like if at all possible:
> * The option to have just one copy of the database per binary. So shared
> across PROJ through GDAL and PostGIS
PostGIS will still have to keep its spatial_ref_sys table since this is something required by the
SF-SQL standard.
> * Be able to compile in the database within the binary and use if from
> memory
> My env is typically statically linked binaries with one binary per
> container and no local disk. I currently have an C data block with the
> data that I write to vsimem and read from there. My solution uses some
> non-public code. An SQLite in-memory database that the entire community
> could use (if selected at build time) would be nicer. I'm sure other
> folks would appreciate the option to not need extra files.
Would you been interested in contributing code to make that possible in proj ? (once classic
file based approach has been added)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180521/f56b8ceb/attachment.html>
More information about the Proj
