[Proj] Use of C++
support at mnspoint.com
Wed May 23 21:51:39 PDT 2018
Hello,
I think that if you want to keep proj. downwards compatible with C (and
C++) then you should keep it standard C. If you use c++ in the library
NOT any "just C" compiler can ever compile it. So as proj. is so small
library I would keep it standard c since nobody really cares if it is c
or c++ - and anybody can write it to c++ or whatever in very small time
- that is not a problem.
So to be able to use proj. in as many targets as possible, also in
smaller devices like hand held devices or so ... I would strongly
recommend to keep it standard c for ever! - But when that is now said
... they most likely do everything else but what is wanted!? haha! (y)
Janne.
Even Rouault kirjoitti 2018-05-23 13:25:
> Hi,
> As announced previously, and given that the SQLite related thread has
> calmed
> down (except license related discussions that aren't directly related
> to it),
> this is the second potentially controversial topic I wanted to discuss.
More information about the Proj
