[Proj] Use of C++
Kurt Schwehr
schwehr at gmail.com
Wed May 23 23:36:24 PDT 2018
Janne,
You mean microcontroller? https://en.wikipedia.org/wiki/MCU
How about naming just one example that you think proj must support?
Make some sort of useful concrete statement.
However, you do appreciate you making me laugh with your C++ comments
trying to troll.
On Wed, May 23, 2018 at 11:10 PM, <support at mnspoint.com> wrote:
> Hello,
> there are very many platforms at the lower level MCU's which mainly use
> standard c and avoid using c++ ... just to keep it simple and easy! - I
> don't want to start listing them here ... they are just too many .. all
> MCU's usually have assembler or c programming environment but seldom c++ is
> used or either easy available.
> Transition to c++ would just add problems later! I have been programming
> c++ since 1995 and I still find it as a rather stupid platform that just
> adds problems - to switch back to lower level if required for example - At
> the moment I would rather hang the guy who invented the whole problem (c++)
> at the first place! All it usually does, it makes programs harder to follow
> and read and especially to port to lower level targets .. which is often
> required and desired in real World projects.
> Janne.
> Kurt Schwehr kirjoitti 2018-05-24 08:04:
> Janne,
> Can you give specific examples of these platforms that only support C that
> you think PROJ should be supporting?
> On Wed, May 23, 2018 at 9:51 PM, <support at mnspoint.com> wrote:
>> Hello,
>> I think that if you want to keep proj. downwards compatible with C (and
>> C++) then you should keep it standard C. If you use c++ in the library
>> NOT any "just C" compiler can ever compile it. So as proj. is so small
>> library I would keep it standard c since nobody really cares if it is c
>> or c++ - and anybody can write it to c++ or whatever in very small time
>> - that is not a problem.
>> So to be able to use proj. in as many targets as possible, also in
>> smaller devices like hand held devices or so ... I would strongly
>> recommend to keep it standard c for ever! - But when that is now said
>> ... they most likely do everything else but what is wanted!? haha! (y)
>> Janne.
>> Even Rouault kirjoitti 2018-05-23 13:25:
>> > Hi,
>> > As announced previously, and given that the SQLite related thread has
>> > calmed
>> > down (except license related discussions that aren't directly related
>> > to it),
>> > this is the second potentially controversial topic I wanted to discuss.
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
> http://schwehr.org
> Proj mailing list
> MNS Support
> NNS Master Navigator Software
> Copyright © Sapper Oy
> www.mnspoint.com
> Proj mailing list
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180523/5ca78638/attachment.html>
More information about the Proj
