[Proj] PROJ 5.1.0RC1
Even Rouault
even.rouault at spatialys.com
Thu May 24 11:52:30 PDT 2018
Kristian,
Tested against GDAL regression test suite and everything is OK
... but I think there's an issue with the libtool versioning
proj 5.0.0 was -version-info 13:0:0 ==> libproj.so.13.0.0
proj 5.0.01 was -version-info 13:1:0 ==> libproj.so.13.0.1
So I think proj 5.1.0 should be -version-info 14:0:1 to generate
libproj.so.13.1.0
Currently -version-info 14:0:2 generates a libproj.so.12.2.0 which would
appear as older than the proj 5.0.x releases.
Even
> All,
> I have prepared the first release candidate for PROJ 5.1.0. This release
> comes with both bug fixes as new features. Please test it on your system
> and report back any problems you may find. The final release is set to
> release on June 1st, assuming that a release candidate can be promoted to
> final version before that. If everything goes to plan, I will call the vote
> for promotion on May 30.
> Download the source distributions here:
> http://download.osgeo.org/proj/proj-5.1.0RC1.tar.gz
> (http://download.osgeo.org/proj/proj-5.1.0RC1.tar.gz.md5)
> http://download.osgeo.org/proj/proj-5.1.0RC1.zip
> (http://download.osgeo.org/proj/proj-5.1.0RC1.zip)
> For a list of changes in the new release, see NEWS:
> https://github.com/OSGeo/proj.4/blob/master/NEWS
> /Kristian
http://www.spatialys.com
More information about the Proj
