[Proj] C++ coding practices w.r.t object ownership
Even Rouault even.rouault at spatialys.com
Sun May 27 14:23:45 PDT 2018
> I'm a bit concerned by all the hidden cost of object duplication with the
> approach I tried. And if you instanciate various projected coordinate
> systems based on the same datum, currently all the datum information would
> be duplicated in each PCS object, whereas with a pointer based approach you
> would have just one instance of it.
I've experienced with the shared_ptr approach in
https://github.com/rouault/proj.4/commit/85f619cbae7a0b2071681e150f93a5301fa32098
The most satisfactory result is the removal of the clone() hacks. Side effect is that the creation of
the GeographicCRS is 30% faster than the previous approach (measured on a 1 million iterations loop)
Even
http://www.spatialys.com
