[Proj] Regression 5.1.0 -> 5.2.0 ?
Thomas Knudsen knudsen.thomas at gmail.com
Sun Nov 4 23:40:44 PST 2018
Søren,
I suppose Even's suggestion will solve your problem - but could you please
tell  whether that is the case?
(just to avoid chasing solutions for problems already solved).
/Thomas
Den søn. 4. nov. 2018 kl. 22.44 skrev Søren Holm <sgh at sgh.dk>:
> Hi
> Great - I look forward to the response fomr Thomas or Kristian.
> Regarding the ressource files. What can be expected as far at
> compatability?
> For my use case having new versions of the resource files be compatible
> with
> old proj-versions would be appropriate. For other people it might be
> opposite.
> søndag den 4. november 2018 21.51.26 CET skrev Even Rouault:
> > Søren,
> > I think the issue is that the _TC32_TD32 definition in the DK file has a
> > Helmert transform that lacks the convention used for rotation terms,
> which
> > is required since PROJ 5.2. So likely adding convention=coordinate_frame
> > would fix the issue (since that was what was implemented before PROJ
> 5.2),
> > but I'll Kristian or Thomas check that this is appropriate.
> Søren Holm
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20181105/88198f52/attachment.html>
