[Proj] Length of a deg in metres
Luís Moreira de Sousa
luis.de.sousa at protonmail.ch
Fri Nov 9 02:30:20 PST 2018
Hi Nicolas,
PROJ itself relies on the GeographicLib package [0] for the computation of geodesics and rhumb lines. Since you are programming in Python, the easiest option is to use directly the GeographicLib port to Python [1].
Regards.
[0] https://geographiclib.sourceforge.io/
[1] https://pypi.org/project/geographiclib/
Email: luis.de.sousa at protonmail.ch
RingID: ring:7ca91d83f4f9dec82fec9f1144b8e5c1ef2a110c
URL: https://ldesousa.github.io
Sent with ProtonMail Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Thursday, November 8, 2018 4:18 PM, Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> I am writing to python code to calculate the length (in metres) of a
> degree of longitude at a certain degree of latitude. I would like to
> take various ellipsoid in mind (WGS84, GRS80, Clarke 1866...). The goal
> is to find the right scale (or z factor) when making slope or shade
> raster models when x and y are in long/lat and z in feet or meters. Can
> someone point me in the right direction to do this in using Proj? Is
> Proj the best option for this?
> Thanks,
> Nicolas
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
