[Proj] Integration of RFC2 work with existing PROJ code: axis order and unit issues
Even Rouault even.rouault at spatialys.com
Sat Nov 17 11:47:11 PST 2018
Hi Martin,
> What about the following policy?
>   * "epsg" in "+init=epsg:4326" refers to axis order as declared in the
>     EPSG database.
>   * For axis order as used in Proj.4, one of the following choices:
>       o Define a new authority name, for example "+init=proj4:4326".
>       o Or append a parameter to the code, for example
>         "+init=epsg:4326;axisOrder=lonlat". This proposal as been
>         discussed at OGC, but I don't think it became official
>         recommendation.
If we go for breaking backward compatibility, your proposal of embedding the
axisOrder override in the CRS designation (could be generalized for projected
CRS too: axisOrder=easting,northing) is rather attractive and would avoid
adding switches to exiting utilities or extra parameters or new variants to
existing API.
I'm not too much for creating a PROJ authority (at least for that purpose
(*)). That would mean either to duplicate & patch a lot of existing EPSG
definitions in the database itself, or add special code to dynamically patch
existing official definitions. But as we support multiple authorities
(currently EPSG, ESRI, IGNF, and possibly other we wouldn't be even aware if
users add their own), PROJ:code could be ambiguous.
Even
(*) The PROJ authority is already used to add new CRS definitions not present
in other authorities, or new transformations between existing CRS. For now it
has only 4 objects :-)
http://www.spatialys.com
