[Proj] finding proj descriptions
Kristian Evers
kreve at sdfe.dk
Tue Oct 16 03:33:48 PDT 2018
Roger,
Take a look at this http://epsg.io/4094 code for instance. Scroll down to
the "Export" section and click on "PROJ.4". This should give you a
PROJ string. I seem to vaguely remember that sometimes it is missing,
which usually corresponds with a system that can't be expressed with a
(legacy) PROJ string.
/Kristian
-----Oprindelig meddelelse-----
Fra: proj-bounces at lists.maptools.org <proj-bounces at lists.maptools.org> På vegne af Roger Oberholtzer
Sendt: 16. oktober 2018 12:17
Til: PROJ.4 and general Projections Discussions <proj at lists.maptools.org>
Emne: [Proj] finding proj descriptions
I used to use http://epsg.io/ to find the proj strings for projections
of interest. I see that the site now only provides an OGP XML
description.
Did I miss something?
Roger Oberholtzer
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
