[Proj] Understanding 2D Helmert
Kristian Evers
kreve at sdfe.dk
Fri Oct 26 07:40:17 PDT 2018
If that is the case it should just be a matter of changing the
type of the output units internally in the operation. If you
submit a new ticket on the github page with a short description
I'll take a look at it within the next couple of days.
Thanks for reporting this.
/Kristian
-----Oprindelig meddelelse-----
Fra: proj-bounces at lists.maptools.org <proj-bounces at lists.maptools.org> På vegne af Tobias Wendorff
Sendt: 26. oktober 2018 15:52
Til: PROJ.4 and general Projections Discussions <proj at lists.maptools.org>
Emne: Re: [Proj] Understanding 2D Helmert
Am Fr, 26.10.2018, 15:43 schrieb Andre Joost:
> But the result of "17.45 0" does not really make sense to me.
> X=2000 results to a new X=34.91.
> Can anybody shed a light on this?
Seems to be in radians: 17.45 to degrees* = 999.8113525
*to degrees: 360/(2*PI()) * 17.45
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
