[Proj] Understanding 2D Helmert
Even Rouault even.rouault at spatialys.com
Mon Oct 29 02:58:14 PDT 2018
> It would probably also be possible to invent a simple text based file format
> for storing the triangles and their related parameters. This would be sort
> of equivalent to a grid file that can be linked to in the database. Is the
> current setup geared for something like that, or is it strictly reserved
> for grid files?
There are 2 possibilities I can see with the current state of the code. Either
use the table that is dedicated to grid transform and invent a method name for
that method, and add the code that translates this into a PROJ string. This
has the advantage that the method that the CoordinateOperation::gridsNeeded()
can be used and users can know that the transform depends on a external
resource they must possibly grab from somewhere. Or just use the capability of
putting an arbitrary PROJ string to describe a transformation between 2 CRSs
codes (blackbox approach).
Even
http://www.spatialys.com
