[Proj] cs2cs - specifying UTM zone on command line
Martin Desruisseaux martin.desruisseaux at geomatys.com
Mon Oct 29 14:04:41 PDT 2018
Le 29/10/2018 à 21:14, Kristian Evers a écrit :
> Okay, so basically encoding the zone in the easting? Better, but I
> still think it is weird. At least it produces somewhat sane output. Is
> that operation used by any CRS in the EPSG database?
I found two:
  * EPSG::32600 - WGS 84 / UTM grid system (northern hemisphere)
  * EPSG::32700 - WGS 84 / UTM grid system (southern hemisphere)
Le 29/10/2018 à 21:37, Charles Karney a écrit :
> Is there a provision for encoding the hemisphere (north/south) to
> distinguish between
Not as far as I can see; EPSG uses two different CRS for the two
hemispheres. However if we use the CRS for North hemisphere with
negative Northing (y) values in the South hemisphere, I would expect the
calculation to work (but did not verified).
Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20181029/007ac7b9/attachment.html>
