[Proj] PROJ 5.2.0
Roger Oberholtzer roger.oberholtzer at gmail.com
Mon Sep 17 02:07:48 PDT 2018
On Mon, Sep 17, 2018 at 9:55 AM Kristian Evers <kreve at sdfe.dk> wrote:
> Roger,
> Probably, yes. Could you share some details on how you got there? Did you use make or CMake?
My mistake. I see that 5.2.0 now requires g++. I did not add that to
my spec file. I thought it was a default thing in the build
environment. Seems not.
If you are curious, I try to maintain builds here:
https://build.opensuse.org/package/show/home:rogeroberholtzer/proj
These are the platforms I test for. There are others that are also supported.
Roger Oberholtzer
