[PROJ] Equivalent of OSRSetFromUserInput in proj 6 API
Even Rouault
even.rouault at spatialys.com
Mon Apr 8 01:15:25 PDT 2019
On lundi 8 avril 2019 13:18:07 CEST Nyall Dawson wrote:
> Hi list,
> While plugging away at the QGIS proj 6 upgrade I came across code
> which uses OSRSetFromUserInput in order to convert any freeform string
> to a coordinate reference system object.
> Is there an equivalent of this in the proj 6 API I should be using
> instead of this?
proj_create() will be able to handle PROJ strings, WKT, AUTH:CODE, OGC URNs
and CRS names (like 'WGS84')
If you pass it a PROJ string that needs to be interpretated as a CRS, you need
to add " +type=crs" to it, otherwise it will be interpretated as a coordinate
operation.
Even
http://www.spatialys.com
More information about the PROJ
