[PROJ] some questions about the Barn Raising
Even Rouault
even.rouault at spatialys.com
Tue Apr 16 10:41:52 PDT 2019
Eduardo,
> I want to promote the initiative "/GDAL Coordinate System Barn Raising"/
> because in Costa Rica there has recently been a change of CRS - from CRTM05
> (EPSG 5367) to CR-SIRGAS (EPSG 8906)
You meant CR-SIRGAS (EPSG *8908*) right ?
This was a very interesting use case that exhibit a few bugs in PROJ I've just
fixed per https://github.com/OSGeo/proj.4/pull/1427 (for PROJ 6.1)
With the fixes, appropriate datum shift, using the Helmert tranformation
registered in the EPSG dataset, is now done when attempting:
$ projinfo -s EPSG:5367 -t EPSG:8908
Candidate operations found: 1
Operation n°1:
unknown id, Inverse of Costa Rica TM 2005 + CR05 to CR-SIRGAS (1) + Costa Rica
TM 2005, 0.5 m, Costa Rica
PROJ string:
+proj=pipeline +step +proj=axisswap +order=2,1 +step +inv +proj=tmerc +lat_0=0
+lon_0=-84 +k=0.9999 +x_0=500000 +y_0=0 +ellps=WGS84 +step +proj=push +v_3
+step +proj=cart +ellps=WGS84 +step +proj=helmert +x=-0.16959 +y=0.35312
+z=0.51846 +rx=-0.03385 +ry=0.16325 +rz=-0.03446 +s=0.03693
+convention=position_vector +step +inv +proj=cart +ellps=GRS80 +step +proj=pop
+v_3 +step +proj=tmerc +lat_0=0 +lon_0=-84 +k=0.9999 +x_0=500000 +y_0=0
+ellps=GRS80
> but I
> still do not understand how this comes to softwares like QGIS or PostGIS
> that are used by many types of users.
* PostGIS 3.0 will incorporate PROJ 6 support. There's already a development
branch for it.
* QGIS 3.8dev has received initial work to support PROJ6, but that might
perhaps take an extra dev cycle to have full support for it.
* Spatialite dev team is aware of the porting work, and will likely start
working on that.
So this is a matter of time before PROJ 6 starts being adopted by upper level
components of the software stack. I also think that real use of the new
capabilities might take a few more time since some porting efforts still rely
on using PROJ strings to describe CRS, which lose the datum information.
Even
http://www.spatialys.com
More information about the PROJ
