[PROJ] [PROJ 6.0.0] Cannot create a Prime Meridian with proj_create_from_wkt
Even Rouault even.rouault at spatialys.com
Tue Apr 30 06:35:39 PDT 2019
On mardi 30 avril 2019 12:41:54 CEST Didier Richard wrote:
> Hi all,
> Still testing the library, it seams that the prime meridian creation with a
> call to proj_create_from_wkt() leads to getting an error. Is it a feature
> (cause one can create an ellipsoid using proj_create_from_wkt()) ?
I probably didn't see the interest of instanciating a standalone prime
meridian object, so yes a "feature" :-)
> By the way, the warnings and errors thrown by proj_create_from_wkt() are not
> "merged" into the error handling API : proj_context_errno() returns NULL.
> Why not pushing back these messages to the error handling API ?
Not sure if you are testing with 6.0 or master, but master should now set a
PJD_ERR_GENERIC_ERROR
http://www.spatialys.com
More information about the PROJ mailing list
