[PROJ] [PROJ 6.0.0] Different behaviors for creating a transformation of type EPSG:9616
Martin Desruisseaux
martin.desruisseaux at geomatys.com
Tue Apr 30 07:40:55 PDT 2019
Le 30/04/2019 à 16:19, Even Rouault a écrit :
> For example, if you would do a transformation from a CompoundCRS to
> another CompoundCRS (or a Geographic3D CRS) with both horizontal and
> vertical transformations, there is nothing in ISO:19111 to model the
> composite of both.
Actually this is modeled with PassThroughOperation +
ConcatenatedOperation. So a transformation between two CompoundCRS with
a vertical component would be like below:
ConcatenatedOperation (a 3D operation in this example)
PassThroughOperation (a 3D operation in this example)
coordOperation = the operation on the horizontal component
modifiedCoordinate = {0, 1}
coordOperation = the operation on the vertical component
modifiedCoordinate = 2
Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190430/8fb8a09c/attachment.html>
More information about the PROJ
