[PROJ] Vector Data Reprojection
ivay
ivaygis at protonmail.com
Tue Aug 20 02:31:37 PDT 2019
Here is projection of the original shapefile with EPSG 4612.
GEOGCS["JGD2000",
DATUM["Japanese_Geodetic_Datum_2000",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6612"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4612"]]
Thank you.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Tuesday, August 20, 2019 6:11 PM, ivay <ivaygis at protonmail.com> wrote:
> Hi,
> I have a shape file with epsg 4612.
> I converted it into new shapefile with epsg 4326.
> When I opened both shape files (with 4612 and 4326 epsg codes), there is no change in the X and Y locations.
> Does both shapefiles (with epsg 4612 and 4326 codes) have same X and Y values?
> My requirement is to convert the original file with "epsg code 4612" exactly into the "epsg 4326" .
> Thank you for your ideas.
> Ivay
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190820/2603b2ca/attachment.html>
More information about the PROJ
