[PROJ] Why is std=gnu89 tested/enabled ?
Markus Metz markus.metz.giswork at gmail.com
Wed Aug 21 12:46:31 PDT 2019
On Wed, Aug 21, 2019 at 2:10 PM Kristian Evers <kreve at sdfe.dk> wrote:
> No, I don’t think so. Internally PROJ defines some math functions that is
first introduced with C99. If the build system detects that they are
available with your compiler the system functions are used instead. As far
as I remember that is the only difference between using C89
PROJ used -std=gnu89 which is not the same like -std=c89, because only
gnu89 includes some C99 features which might not be available on Solaris
with -std=gnu89. If PROJ wants to enforce a particular standard, it should
probably use -std=c<xy> instead of -std=gnu<xy>, if PROJ is supposed to
compile on non-GNU (double negation) systems.
my2c
Markus M
> and C99 to build PROJ 5.2.0. Try running the test suite, it should give
you a good indication if it works or not.
> /Kristian
> On 21 Aug 2019, at 13:55, Dechaux Eric CEN (BCQ STIG) <
eric.dechaux at gendarmerie.interieur.gouv.fr> wrote:
> Thanks Kristian,
> On Solaris, NAN is not available with C89. Is there an issue to build
proj 5 forcing C99 by replacing -std=c89 to -std=c99 in the Makefile, after
configure ?
> Regards.
> Le 21/08/2019 à 12:43, Kristian Evers a écrit :
> Eric,
> A C++11 compatible compiler is only required for PROJ 6 and onwards. This
was introduced with RFC3 [0]. Previous versions was strictly C89, hence the
enforcement of that standard in PROJ 5.2.0.
> /Kristian
> [0] https://proj.org/community/rfc/rfc-3.html
> On 16 Aug 2019, at 14:57, Dechaux Eric CEN (BCQ STIG) <
> Greetings,
> I have been investigating proj 5.2.0 build failure on Solaris 11.3 for
amd64. At some point the build stops on error because of the NAN being not
declared :
> gcc -DHAVE_CONFIG_H -I.
-DPROJ_LIB=\"/appli/stig/11.3-20190816-104632/share/proj\" -DMUTEX_pthread
 -D_FORTIFY_SOURCE=2 -I/usr/include/pcre
-I/appli/stig/11.3-20190816-104632/include -Wall
-Wdeclaration-after-statement -Wextra -Winit-self -Wunused-parameter
-Wmissing-prototypes -Wmissing-declarations -Wformat
-Werror=format-security -Wno-format-nonliteral -Wlogical-op -Wshadow
-Werror=vla -Wdeclaration-after-statement -Wdate-time -Wfloat-conversion
-std=gnu89 -m64 -O2 -fstack-protector-strong -fpic -fPIC
--param=ssp-buffer-size=4 -I/appli/stig/11.3-20190816-104632/include
-DHAVE_C99_MATH=1 -MT proj_strtod.o -MD -MP -MF .deps/proj_strtod.Tpo -c -o
proj_strtod.o proj_strtod.c
> gie.c: In function ‘cart_selftest’:
> gie.c:2008:20: error: ‘NAN’ undeclared (first use in this function)
>      a = proj_coord(NAN, NAN, NAN, NAN);
> gie.c:2008:20: note: each undeclared identifier is reported only once for
each function it appears in
> make[2]: *** [gie.o] Erreur 1
> As the documentation specify a C and C++11 compiler is required I changed
the CFLAGS to include -std=gnu11. The build and checks run without errror.
Solaris 11.3 is bundled with GCC 5.3 with uses gnu11 by default for C and
there should be no reason to force for it on the CFLAGS.
> I noticed the configure script detects and automatically adds -std=gnu89
to the CFLAGS :
>     checking whether C compiler accepts -Wdocumentation
-Wno-documentation-deprecated-sync... no
>     checking if -std=gnu89 can be enabled... yes
>     checking whether C++ compiler accepts -Wunused-private-field... no
> On Solaris this disables the NAN macro as it is C99:
> $ cat test.c
> #include <stdlib.h>
> #include <math.h>
> int main (void) {
>         float f ;
>         f = NAN ;
>         exit (EXIT_SUCCESS) ;
> $ gcc -std=gnu89 test.c
> test.c: In function ‘main’:
> test.c:7:6: error: ‘NAN’ undeclared (first use in this function)
>   f = NAN ;
> test.c:7:6: note: each undeclared identifier is reported only once for
> $ gcc -std=gnu99 test.c
> $ gcc -std=gnu11 test.c
> What is the purpose of forcing C standard to gnu89  ?
> Thanks.
> -- Eric
> Ce message �lectronique et tous les fichiers attach�s qu'il contient sont
confidentiels et destin�s exclusivement � l'usage de la personne � laquelle
ils sont adress�s. Si vous avez re�u ce message par erreur, merci de le
retourner � son �metteur. La publication, l'usage, la distribution,
l'impression ou la copie non autoris�e de ce message et des attachements
qu'il contient sont strictement interdits.
> En cas d'urgence, composez le 17 ou le 112.
> Afin de contribuer au respect de l'environnement, merci de n'imprimer cet
e-mail qu'en cas de necessite.
> This e-mail and any files transmitted with it are confidential and
intended solely for the use of the individual to whom it is addressed. If
you have received this email in error please send it back to the person
that sent it to you. Unauthorized publication, use, dissemination,
forwarding, printing or copying of this email and its associated
attachments is strictly prohibited.
> In case of emergency, dial number 17 or 112.
> To contribute to the environmental protection, please print this e-mail
only if necessary.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
> <signature.png>
only if necessary.
> PROJ mailing list
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190821/48c11af4/attachment.html>
More information about the PROJ mailing list
