[PROJ] Custom coordinate reference system
Even Rouault even.rouault at spatialys.com
Sun Dec 1 04:39:08 PST 2019
Michel,
It would be fair for readers here if you mentionned that you already reported
this to QGIS in
https://github.com/qgis/QGIS/issues/31106
and you got a detailed answer in
https://github.com/qgis/QGIS/issues/31106#issuecomment-558383488
explaining it was a QGIS limitation currently.
You could potentially add your own CRS and its transformation to WGS84 by
hacking directly into the PROJ database. Relevant files in PROJ to edit would
be data/sql/projected_crs.sql (and potentially geodetic_crs.sql and
geodetic_datum.sql if there is no existing underlying Geographic CRS and datum
in EPSG) and data/sql/helmert_transformation.sql. Or insert directly the
entries in proj.db
You'd probably need to rerun QGIS crssync program afterwards
Hum actually as you specifically want the +exact keywords of proj=helmert, you
should rather edit other_transformation.sql than helmert_transformation.sql,
to add directly the pipeline transforming between the 2 underlying geographic
CRS. A (really dummy) example of registering a PROJ pipeline string as a
transformation is in
https://github.com/OSGeo/PROJ/blob/master/test/unit/test_factory.cpp#L2074
Even
http://www.spatialys.com
More information about the PROJ mailing list
