[PROJ] Reversing a coordinate operation via proj api
    Even Rouault
    even.rouault at spatialys.com
    Thu Dec 12 15:55:13 PST 2019
Hi Nyall,
> If I have a proj string representing a coordinate operation, is there
> any existing proj c api to reverse this operation?
Do you mean, to get a PROJ string corresponding to the reverse operation ?
Then, no. Although that would not be too complicated: separate the steps,
reverse their order, for each step add +inv (or remove +inv if already
present), and reconcatenate them.
(with PROJ master, you'd need also to change +omit_fwd to +omit_inv and
+omit_inv to +omit_fwd)
If you just want to apply the reverse operation on coordinates, you can call
proj_trans()/proj_trans_array()/etc. with direction = PJ_INV instead of PJ_FWD
Even
http://www.spatialys.com
More information about the PROJ
